EK all the way, my entire loop is there stuff and it is amazing build quality and works great! I have the EK Supremacy EVO in the black and its amazing, great quality block! They also offer an MX which is slightly cheaper and will get u basically the same performance give or take 3c
'FrostNova' https://uk.pcpartpicker.com/user/Samsterstorm/saved/WtBWGX :
CPU: Intel 4790k | MB: Asrock Z97 Extreme6 | GPU: Gigabyte GTX 970 G1 Gaming (+200, +250) | CASE: NZXT H440 (Black & Blue) | COOLER: Full EK 240mm CPU Loop | RAM: 16GB Hyper-X Fury (4x4GB @2133mhz) | STORAGE: Seagate Barracuda 1TB & Hyperx 120gb SSD | PSU: Corsair RM650 | SCREEN: Benq G2750 | LIGHTING: Deepcool RGB LED Kit | KEYBOARD: CM Devastator | MOUSE: Logitech G502 | HEADSET: Hyperx Clouds White
https://linustechtips.com/topic/676162-recommend-me-a-cpu-block/#findComment-8704580
My entire loop is also from EKWB and no problems so far.
Got some block for like 50-60€, so that's kinda cheap for that kind of performance :)
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/676162-recommend-me-a-cpu-block/#findComment-8704589
6 minutes ago, Exposal said:
Only thing that is turning me off the EK is all the silver mounting hardware, wish you could get it in black.
You could paint it?
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/676162-recommend-me-a-cpu-block/#findComment-8704616
Image result for ek cpu clock
Or are you just talking about the screws?
Because the mount is completely black...
https://linustechtips.com/topic/676162-recommend-me-a-cpu-block/#findComment-8704633
EK or Koolance are the best in my opinion.
My Build:https://linustechtips.com/main/topic/795406-mini-itx-build/   PSU TIER LIST
"The difference between genius and stupidity is that genius has it's limits." - Albert Einstein
"If my doctor told me I had only six minutes to live, I wouldn't brood. I'd type a little faster." - Issac Asimov
"Headward, free now to rise." - Principal Vagina
https://linustechtips.com/topic/676162-recommend-me-a-cpu-block/#findComment-8704786
4 minutes ago, Exposal said:
the Screws
I found this:
http://www.sidewindercomputers.com/ekeamohfbl.html
https://linustechtips.com/topic/676162-recommend-me-a-cpu-block/#findComment-8704826
I think that was discontinued though :( was looking on EKWB site and it was under discontinued
Some retailers or sites like ebay will probably have it available.
Just google
EK-CPU Easy Mount HF - Black
and try to find a place that has some.
https://linustechtips.com/topic/676162-recommend-me-a-cpu-block/#findComment-8704858
3 minutes ago, Exposal said:
Don't think it compatible with the evo block sadly :(
I would make it work. Just takes some screws and washers and a bit of improvisation.
But if you're not into making stuff work for you then just paint your own mounting hardware or pay someone to powedercoat or anodize it for you.
https://linustechtips.com/topic/676162-recommend-me-a-cpu-block/#findComment-8704890
