2 minutes ago, Aytex said:
Like a thermaltake p5 on the wall?
Or use your own case, you will probably have to drill it into the wall, i don't think adhesive would stick/hold something that heavy.
I have a galaxy evo and I'm thinking of something like this
with the parts of course
https://linustechtips.com/topic/674638-case-wall-mount/#findComment-8688239
industrial adhesive then.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/674638-case-wall-mount/#findComment-8688276
36 minutes ago, Dan Herdman said:
Any other ways I don't want to be drilling
The computer is going to be very heavy without drilling something into the wall it will fall.
Think of it like mounting a big expensive tv to the wall you can't just use double sided tape to hold it up, or maybe go extremely ghetto with a few rolls of duct tape.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/674638-case-wall-mount/#findComment-8688375
What about a TV wall mount
https://linustechtips.com/topic/674638-case-wall-mount/#findComment-8692683
TV's have VESA mounts built into the back of the TV, where a TV wall mount uses the VESA holes to screw into. Your case does not have VESA holes. You would have to drill holes into the case to make it work.
There is no way to do this without either drilling into your case to attach it to the wall, or weld your metal case to a bracket to attach to the wall. Too much weight for any type of adhesive.
https://linustechtips.com/topic/674638-case-wall-mount/#findComment-8722404
On 19/10/2016 at 9:05 AM, elkenrod said:
Are you going for aesthetics or are you just looking to save space?
If you can mount in the corner, you have more support options.  If it's just a side wall, you might want to look into mounting the components without the case.
Aesthetics
https://linustechtips.com/topic/674638-case-wall-mount/#findComment-8733030
3 hours ago, Dan Herdman said:
Like if I could have my computer on a tv mount then my monitor mounted to the computer
It would have to be a light monitor, and you may want to add weight (10-20lbs) into the bottom of the pc if you do this so it doesn't tip over, also make sure that the side panel is thick enough to support the monitor, it will most likely need some sort of reinforcement.
https://linustechtips.com/topic/674638-case-wall-mount/#findComment-8733631
If you were to wall mount a case I wouldn't recommend to mount it via the side panel since it's not designed to hold the entire weight of the case with the metal clips. If you wanted to do something like that making a bracket so it bold through the frame of the chassis would be your best option.
https://linustechtips.com/topic/674638-case-wall-mount/#findComment-8735122
If it's a flat mount or tilt being put into a stud it'll hold. I test every mount I put on the wall by hanging onto it. If it holds its good. So far i've been able to put about 200lbs on the mount.
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/674638-case-wall-mount/#findComment-8735608
