Hi, I have had a 5960X for about a year now running on a custom loop but I now want to make maintenance more simple and I want to downsize my case so was wondering what coolers are recommended for this CPU I was looking at the NZXT Kraken x61 but not sure if that is enough for the 5960x as I do have it overclocked.
Custom PC:
Intel Core i7 5960X GTX1080 Strix | 64gb 2400mhz DDR4 Corsair Vengeance Ram | Samsung S951 256gb M.2 | 4TB WD Blue SSHD | EVGA Supernova G2 1300watt PSU | Acer XB270HU | Corsair K95 RGB | Corsair M65 RGB |
https://linustechtips.com/topic/674633-5960x-cooling/
Well, the 5960X only puts out about 140W OC'd, so I think a copper shim will do.
Just joking, any thicker 120 or 240mm AIO, or any air cooler with more than 6 heat pipes should do.
REMILIA Mk.IIIG CPU: Ryzen 7 5700X3D, Cooler: Gelid Sirocco (Arctic MX6), RAM: 4x 8Gb sticks of Patriot Viper Steel Series 3600 CL17, Mobo: AsRock X570 Taichi, GPU: Inno3D RTX 3080 iChill x4 10G, Storage: 1TB Intel 670p NVME SSD boot drive, a few 1TB and 512gb SATA/NVME SSDs for game storage, 6 hard drives:2-12 TB, PSU: Montech Century II 850W, Case: Silverstone FLP02, PCIE Cards: Cheap Chinese Marvell 88SE9215 4 port SATA card, Sonnet Allegro USB3.2 Card Monitors: ViewSonic Elite XG270QC (165hz, 1ms MPRT, 1440p, VA, Freesync PP, pneumatic stand), electriq 27qhd180i (IPS, 180hz, 1440p, 1Ms), iiyama G2530HSU-B (75Hz, Freesync, one in landscape, one in Portrait, all on pneumatic monitor stands).
Mic: iSK UPM-1 USB XLR interface with Neewer NW700, Audio: Sabaj A3 160W DAC/AMP + Wharfdale Diamond 220 + Mission MS6 Sub, Fiio K11 R2R DAC + Douk P5 (Toshiba Tubes), Sendy Peacock, Mouse: Glorious Model I, Keyboard: Glorious GMMK ISO with Mengmoda MMD Tactile (main) and Kailh Box Navy (Function keys), Tribosys 3203 brush lubed, Taihao Green forest caps.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688109
3 minutes ago, paprikman said:
That's just not enough for such overclocked cpu. Stay with custom loop, it's way better than this AIO.
You can always do DIY mod for this case, if you need (you know, cut something, then weld it and so on).
If I downsized to single 360mm would that be enough for the 5960X then as I want to get the NZXT H440 case but need the hard drives in the front so would have to ditch my second 360mm
Custom PC:
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688113
To be honest, any AIO is not going to be enough.
An overclocked 5960x throws out a ton of heat.  If I were you, I'd stick with the custom loop, but reconfigure it for your new case.  Radiator surface area or high fan speeds are really you're only two options.  Well, there's lower voltage/clock speed, but that's really not an option is it?  :D
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688114
Yes.  Like I mentioned in my previous post.  It's more radiator surface area or more fan speed.  Pick your poison.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688120
You need at least 2 thick 360mm rads for this thing to make your watercooling worth it. If you want both power and small size, then watercooling and 5960X are not for you.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688121
2 minutes ago, done12many2 said:
Very wrong.
Well, I used to cool a FX 9590 with a 240mm AIO and it did fine, and that's a much hotter CPU.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688122
At the moment I have the 5960X at 4.5Ghz 1.28v with the two Titan X (Maxwell) in the loop with dual 360mm 30mm Black ice rads but  hopefully in January/Feb the 1080ti will come out so I can go down to one card from the Titan X's (the heat and the SLI issues are annoying) and so it will be just the cpu in the loop on it's own as I will just air cool the gpu
Custom PC:
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688126
To be honest, you're already running thinner that I'd be comfortable with.
With all GPUs removed from the loop, you should technically see a slight improvement with a single 360mm on your 5960x alone.  Two Maxwell Titan Xs put off a lot of heat so you'll probably see slightly cooler temps with a single 360mm on the 5960x by itself.
I can't imagine running a 1080Ti (if they actually make them) without water cooling.  :(
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688150
I'm not debating what chip runs "hotter."  I'm just saying that your "140W Oc'd" statement was wrong.
You're confusing TDP for actual power usage and it doesn't work like that.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688159
I'm saying a 240mm AIO did fine with a far hotter CPU, so is fine with a colder one.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688163
With all GPUs removed from the loop, you should technically see a slight improvement with a single rad on your 5960x alone.  Two Maxwell Titan Xs put off a lot of heat so you'll probably see slightly cooler temps with a single 360mm on the 5960x by itself.
I get good temps at the moment max I have seen my cpu hit is 68C and my gpu's hit the low 50's. I did consider changing things up a bit in my pc and going to a 6800k or completely platform to a 6700k as I no longer use my cpu for super heavy multicore stuff (no longer doing 3D rendering)
Custom PC:
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688165
The 5960X puts out 140W stock, that's the TDP of al Haswell-E and Broadwell-E CPUs.
Overclocked, it can easily output 300W.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688168
Comparing temps of two different chips isn't how it works.
It's the only way to do it unless you have expensive equipment to measure how much heat your chip in particular produces.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688175
If that's the case, you could definitely move to a 6700k/7700k setup, but once you give up that 5960x, you're going to miss it.  :D
I wouldn't got down to a 6800k.  Either keep your current chip or go with a Skylake rig.  Skylake chips are so much easier to cool than a 5960x, 6900k, or 6950x.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688184
First off, how the living f*ck can you afford one of those.
I think an overclocked cpu like that should get something a little better.
i like trains 🙂
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688189
Definitely go for the chips that @done12many2 said, 5960x would be a waste of power if you weren't using its full potential.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688193
Yeah I will miss the extra cores lol I did a test and disabled 4 cores to replicate a 4790K's performance and my average FPS was about the same but my minimums and max fps was much higher with 8 cores 16thread and also have a lot open in the background when I game so the extra cores help there too.
Custom PC:
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688194
That's not quite how TDP works. TDP is the rated amount of heat energy that needs to be dissipated by a cooler for any given CPU, not the actual total power used by the CPU. So at stock it would be 140W of heat energy + the power of the actual CPU working (not 100% of the energy a CPU uses is converted to thermal energy, that would mean the CPU is doing nothing but generating heat).
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688195
He's talking about how much power the CPU actually draws when overclocked, not TDP.
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688201
Right, the TDP is not the amount of power the CPU draws. The CPU uses more power than the TDP since some of the energy is used for actual processing, not just generating heat.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/674633-5960x-cooling/#findComment-8688212
