Media device for a TV!
Go to solution Solved by CAKEwasTRUE,
WD TV Live. There is a lot of options, but I just like the WD TV Live the best.
Chromecast
Thanks!
So my grandpa is getting a new PC and has a 55" LCD in his bedroom.
He wants to know if their is a Device that can plug into your TV and you can view media from a shared folder on the PC such as Movies, Music, and photos!
Anyone know of such a thing?
work it ᕙ༼ຈل͜ຈ༽ᕗ harder, make it (ง •̀_•́)ง better, do it ᕦ༼ຈل͜ຈ༽ᕤ faster, raise ur ヽ༼ຈل͜ຈ༽ノ donger
ᕙ༼ຈل͜ຈ༽ᕗ HARDER, BETTER, FASTER, DONGER! ᕙ༼ຈل͜ຈ༽ᕗ
https://linustechtips.com/topic/67393-media-device-for-a-tv/
It need to be WiFi because his house isn't wired for cat5
Forgot to add!
https://linustechtips.com/topic/67393-media-device-for-a-tv/#findComment-922219
Chromecast
Thanks!
https://linustechtips.com/topic/67393-media-device-for-a-tv/#findComment-922241
Chromecast all the way.
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/67393-media-device-for-a-tv/#findComment-922278
you have an extra xbox 360 lying around suprisingly it works well streams every thing I got down to my hdhomerun prime. For once microsoft made something that actualy works and works well
https://linustechtips.com/topic/67393-media-device-for-a-tv/#findComment-923414
I have a ps3 but it dosent work with mp4 or ACC playback movies and sound like 15% of the time it plays them.
https://linustechtips.com/topic/67393-media-device-for-a-tv/#findComment-923759
