Mionix Castor or Logitech G Pro?
Solved by Aytex,
G and the Castor are two different shaped mouses, one is ergonomic than the other, if you like a tight fit in your palm go for the castor, if you don't then go for the G
Hellowpplz ·
Atheos ·
Posted in Peripherals0 -
2
johnny45 ·
Posted in Linux, macOS and Everything Not-Windows0 -
DJpanda808 ·
Posted in Displays2 -
JakubR8 ·
Posted in Power Supplies8 -
AccordingOne ·
Posted in New Builds and Planning7 -
1
Plutous ·
Posted in General Discussion2 -
9
