Will a msi gtx 750 ti ,asus h170pro gaming motherboard ,amd black addition a10 apu work together?
Is powercolour amd/ati radeon r7 360 better than 750 ti ?
Which is the best motherboard gigabyte g1 sniper B7 or msi B150A gaming pro or asus 170pro gaming motherboard?
https://linustechtips.com/topic/672730-help/
Neither GPU you mentioned are good for today's AAA games.
and all three motherboards seem to be of similar quality.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/672730-help/#findComment-8668631
OK first off the motherboards you are talking about are Intel motherboards so you would need to go with a compatible Intel cpu. To ensure everything works together I would suggest planning your build using pcpartpicker.com they will tell you if things aren't compatible and give you options that are compatible
https://linustechtips.com/topic/672730-help/#findComment-8668634
Just now, frozeNNN said:
Aren't you talking about Intel's motherboard and AMD's cpu? That won't work m8
Lol I missed that. Just goes to show how tired I am.
https://linustechtips.com/topic/672730-help/#findComment-8668641
