Just now, honna1612 said:
NETWORK SPEED INTERNET please stop spreading nonesense.
One is LOCAL FILE TRANSFER the other is INTERNET FILE TRANSFER.
(The first one has nothing to do with country and your ISP)
Ok, ok, ok, I should've made this point in the first post:
No need to be a complete douche bag about it
Second, the OP is talking about his internet speeds (did I just trigger you more by saying that?)
47 minutes ago, TheFault_02 said:
No my internet speed is fine i get 150 down and 15 up over ethernet but only when I'm using the built-in card from my laptop is when i get 15-25 down and 15 up
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/672508-i-need-help/page/2/#findComment-8666600
3 hours ago, TheRandomness said:
Wifi is slower than Ethernet and always will be. Nothing you can do about it.
Although WiFi is slower, its not that much slower. My Wireless N WiFi card for my desktop was getting 90/12 which is what we are subscribe to. The OP might have a shitty WIFI card, or I have heard that some laptops that are built with Aluminum could cause reception issues.
To further add, my sister had a single band Wireless N card in her laptop. I got her upgraded with a wireless AC adapter. She said speeds and range improved. Depending on the laptop manufacture the OP could find a list of internal adapters that could be compatible. Thats if the OP is going to tear the machine down himself. If not just by a USB dongle, I would suggest one with an External Antenna. I personally dont have any suggestions. As Im not a big fan of USB adapters.
https://linustechtips.com/topic/672508-i-need-help/page/2/#findComment-8667140
