ive had a problem for months and before i buy anything i need to know what to buy and whether or not its just bad luck
i7 has a stuttering problem
phenom 2 doesnt
the ram i have came from that phenom 2 computer, so is it possible its the only one actually compatible with that ram (even though all the other boards and cpus ive used never had an incompatibility error) or that the storage is too slow causing the i7 to stutter, or theres something wrong with the i7?
it's strange because it stutters more sometimes and sometimes it doesnt at all. some games don't do it for what ive noticed, but TF2 has this problem almost cancerously.
and before you ask, i tried everything software side afaik
But first, let's talk about parallel universes.
Intel i7-4790k undervolt, NVidia EVGA GTX 980Ti SC Reference, NVidia EVGA GTX 480 SC Reference, ASUS Z97-A/USB3.1, SK Hynix SL308 240GB, WD Green 2TB, Hynix 1333 8GB (4x2), XFX Core Pro 850w, NH-U12S, 4x NF-F12's, Sennheiser HD 558's, Blue Yeti, Corsair K70 (red), Logitech MX Master, XBox One Controller, ASUS VG248QE 144Hz, HP 2010i
https://linustechtips.com/topic/671942-is-cpu-or-ram-the-problem/
ive tried other ram and it was persistent through the other stick, but this stick was in the other computer the phenom came in (i bought it a year ago just to keep it running since i obviously took the ram out of it)
two fx-6300's died before but i think it was just shitty silicon
Run memtest on the ram.
Try reinstalling the game.
Or see if your drive is at 100% when the stuttering happens.
I really doubt that the cpu is the issue.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
downloadmoreram.com
/s
try buying new RAM maybe? I'm not sure.
  • CPU: Intel Core i7-6700k @4.3ghz, Motherboard: Gigabyte Z170X Gaming 7, RAM: Corsair Vengeance LPX 16GB @2400mhz, GPU: Gigabyte GTX 1080 G1 , Case: Corsair 300R, Storage: Samsung 850 EVO 256GB SSD, WD 1TB Black HDD, WD 2TB HDD PSU: Evga SuperNova 750 G2, Display: ASUS VG248QE @144hz, Cooling: Cooler Master V8 GTS, Keyboard: Corsair K95 RGB Platinum, Mouse: Logitech G502 Lightspeed, Sound: Phillips SHP9500 + VModa Boom Pro, Operating System: Windows 10 Pro
ive ran memory tests and nothing
4+ different windows installs
no way of actually seeing if its at 100% since the other screens freeze too i think and my pc is perpendicular relative
1 minute ago, Festive said:
downloadmoreram.com
/s
when people are asking for help, there's always that one guy in the replies that thinks he's a pvt. joker.
No idea what "perpendicular relative" is, but if you have other screens that freeze as well, it could be an overheating issue, gpu driver issue, or a psu issue.
it's not overheating, ive tried different gpus and even brands, and it COULD be the PSU but its seasonic based and i dont have another to test.
it means it's 90 degrees sideways.
If their was something wrong with the i7 it likely would just crash
Are their any differences in software you have now such as OS version (for instance anniversary update), did you recently change drivers setting etc, has the gpu remained the same, btw the 100% thing is possible to check in windowed mode and something like MSI afterburner
 side note If your playing at an unlimited frame rate (ie no vsync gsync or frame cap) you may want to stop to see if the issue goes away as a result
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/ Tier Breakdown (My understanding)--1 Godly, 2 Great, 3 Good, 4 Average, 5 Meh, 6 Bad, 7 Awful
when i said i tried everything, i meant it
seriously
oh well, got to remember everyone's always stupider than yourself
Well...WD Caviar Green as OS drive?
Probably the cause, 5400 / 5900 RPM HDD with variable speed (can go lower) depending on load.
What storage drive is your Phenom II system using?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
seriously
Usually when people say they have "tried everything" they haven't because it is almost impossible to go through every possible thing that it could be, you are going to get better help if you list out what you have done.
You never answered about the hdd usage, my bet is that the hdd is the issue.
