Just now, aries757 said:
do gtx 970's work? r9 290? i want to either dual boot windows/linux , windows/mac, i can find 290 and 970 under 200 on ebay, so
mac is pretty complicated as not too many GPU's are supported driver wise.
Linux I have no idea but I would assume all the mainstream GPU's have drivers. :)
hello again :)
Linux is pretty straight forward, you can use their online search tool to find the driver for your OS, in your case here:
http://www.nvidia.com/download/driverResults.aspx/106780/en-us
Mac is a different story. There's some unofficial NVIDIA drivers I've used but it's still a gamble. Can't remember where I found mine but this looks like a good resource:
http://create.pro/nvidia_drivers
Can't help you with AMD, but Hackintosh from my experience doesn't play nice with it. I would always stick with NVIDIA in terms of software support
For the most part, Linux runs on all GPUs actively supported by Intel, AMD, and NVidia, and most GPUs that have long since been dropped from support. Either GPU will be fine, but the 290 will likely have better driver support.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
GTX 960 worked great with Linux.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
