1 minute ago, airdeano said:
if properly done can lend a tad to thermal transfer. right off any RMA return for the future.
kinda a reason it was cheap for one. might be a non-lottery winner. won't know till it is booted and tortured.
The guy said it was fully functional so I guess I will see why mess I got myself into. Hopefully it works.
https://linustechtips.com/topic/670211-cpu-lapping/#findComment-8641725
11 minutes ago, Ronald Browen said:
I recently bought an AMD FX 8320 and an Radeon 7950 to bring my rig up to speed enough to meet the minimum requirements of DOOM. I got the processor from some guy on eBay for $70 and it was lapped. Was that a good Idea?
lapping just means they tried to smooth out the IHS, it could cool better, If they messed it up during the process it might not boot at all, but if it boots, its perfectly normal and shouldn't haven't any issues as lapping wouldn't affect anything else.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/670211-cpu-lapping/#findComment-8641762
16 minutes ago, airdeano said:
chuck it up in a mobo and thrash it..
what mobo are you using?
I am using a gigabyte GA-78LMT-USB 3.0 REV 6.0
With AMD FX 6350 8GB RAM Radeon 7870 6m (only one monitor) and a 500w power supply
Why would it not boot? Isn't the processor under that cover that they are sanding? Why would it not boot? What causes it to not boot? Sorry but I like to ask questions
https://linustechtips.com/topic/670211-cpu-lapping/#findComment-8641766
I don't think you understood me. I meant the only danger or risk of buying a lapped CPU, is if it was damaged in the process, in which case it probably just would not boot. So I said if it boots, then it was never damaged and the lapping will have no negative affects at all.
https://linustechtips.com/topic/670211-cpu-lapping/#findComment-8641792
Okay thanks. I was asking how does a processor get damaged by lapping it?
https://linustechtips.com/topic/670211-cpu-lapping/#findComment-8641880
carelessness, like on an AMD CPU, you could accidentally bend/break pins.
https://linustechtips.com/topic/670211-cpu-lapping/#findComment-8641883
Pretty much everything you would need to know about what it is, and what it does, and how its done.
https://linustechtips.com/topic/670211-cpu-lapping/#findComment-8641901
More like "no it does not make any noticeable real world difference.
https://linustechtips.com/topic/670211-cpu-lapping/#findComment-8641940
