My computer won't connect to ethernet or send sound to head phones
Solved by Enderman,
1 minute ago, zconflictz7 said:I already had windows 10. But this update was wierd. It was like"hi" "we just updated your computer" it changed the looks of some stuff.
Anniversary update?
If you can't connect to internet or use audio it's probably your motherboard drivers not working correctly.
If you upgraded from windows 7/8 to 10 then that would be the reason and you should go do a clean install right now.
Otherwise, you can try getting those drivers onto a USB drive from another PC that has internet connection, and then try installing those.
