Just now, Verydoge69 said:
@brob i dont like how that looks
You don't like side-by-side or above-below. Consider using just one monitor. If you really want two, try arranging them at 90 degrees, user is origin. That way, you are only ever looking at one.
https://linustechtips.com/topic/665103-pc-setup-problem/#findComment-8589562
if you don't like em side by side or on top of each other, you are pretty much out of options. you could do the 90 degrees thing stated above, or just get a 27 inch monitor and get used to playing pc games on it.
https://linustechtips.com/topic/665103-pc-setup-problem/#findComment-8589586
