Mbps? Are you referring to internet speed? That has nothing do to with what is compatible with your system.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/664677-i-need-help/#findComment-8584755
Can you explain exactly what you're referring to? Network speed and internal system bandwidth aren't the same thing.
https://linustechtips.com/topic/664677-i-need-help/#findComment-8584770
10 minutes ago, Totallygamer2017 said:
I need help How much mbps do i need for the 1080 for gaming for my new computer i got 75 mbps
Your screen and game resolution isn't affected by your internet speeds. All game files are stored locally on your computer, which is ran by your hardware. Your online gameplay experience is affected by your ping (usually a game will say it in "ms", the lower the better), not by your bandwidth (maximum speeds).
https://linustechtips.com/topic/664677-i-need-help/#findComment-8584791
  • 4 weeks later...
11 minutes ago, Totallygamer2017 said:
Can my internet hold it
It has nothing to do with internet speed.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/664677-i-need-help/#findComment-8718830
