Cooler for 6600k
Go to solution Solved by kosamchetoo,
For 4.5GHz or higher overclock you need:
Air: Noctua NH-D14 or NH-D15
Water: Corsair H100i or 110i or NZXT Kraken x61
1 minute ago, Justinas said:
I need cooler for 6600k I will be oc'ing it to 4,5ghz my case can fit any cooler my ram will be hyper x fury ddr4 and my buget is about 130€
if you want a slim cooler, get a cryorig c7. if you have plenty of height clearence, get a hyper 212 evo. you probably wont be able to go all the way to 4.5ghz though
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/663909-cooler-for-6600k/#findComment-8576676
If your budget is 130 euro you're going to want to get a AIO liquid cooler if possible.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/663909-cooler-for-6600k/#findComment-8576680
i7 6800K
Corsair H110i GT
Asus ROG Strix X99 Gaming
Corsair Vengeance LPX (4x4GB) 3200MHz
Samsung 850 EVO 500GB
Seagate Barracuda 3TB
R9 270X
NZXT H440 (Black/Red) 2015 Edition
EVGA SuperNOVA P2 850W
BenQ XL2411Z
https://linustechtips.com/topic/663909-cooler-for-6600k/#findComment-8576683
definately get an AIO water cooler. It will allow for doog ram clearance and maximum overclocks. Personally im a fan of the corsair H110i
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
https://linustechtips.com/topic/663909-cooler-for-6600k/#findComment-8576694
I have the Noctua NH-D15. If your case is wide enough you can rise the 2nd fan to give enough clearance for high profile ram. Or just use one fan mode and you are golden.
There are lots of reviews on this air cooler. Mine runs very quiet under load and actually quite a bit cheaper than the AIO ones.
Before this I had the 212 Evo, great cost-to-performance ratio. Ran a little too loud for my comfort. However if you have the budget I definitely recommend something like Noctua or AIO liquid cooler.
https://linustechtips.com/topic/663909-cooler-for-6600k/#findComment-8576793
I hit 4.5 Ghz on my 4690k using a simple tower cooler with one fan - Noctua NH12.  I also have lots of case fans feeding in fresh air.  The massive double tower coolers are definitely better, but not necessary.
i7 4790k @4.7 | GTX 1070 Strix | Z97 Sabertooth | 32GB  DDR3 2400 mhz | Intel 750 SSD | Define R5 | Corsair K70 | Steel Series Rival | XB271, 1440p, IPS, 165hz | 5.1 Surround
PC Build
Desk Build
https://linustechtips.com/topic/663909-cooler-for-6600k/#findComment-8576802
Where are you shopping/located?
Moved to Air Cooling.
https://linustechtips.com/topic/663909-cooler-for-6600k/#findComment-8577535
8 minutes ago, Justinas said:
Lithuania, skytech.lt 1a.lt varle.lt
Kotestu: https://www.varle.lt/ausintuvai/scythe-kotetsu.html
or Ninja 4: https://www.varle.lt/ausintuvai/scythe-ninja-4.html
https://linustechtips.com/topic/663909-cooler-for-6600k/#findComment-8577720
