HI guys, next week I plan to buy new power supply and I already have 2 options. I'm gonna buy from these two, but I can't decide which one to choose. So I wanna hear your opinions. :)
The first one: XFX - Well, it's oem is well known Seasonic, which means it's high quality, plus it has hybrid mode of fan and is fully modular.
Second one: FSP - It's a FSP itself, one of the leaders in power supply manufacturers, also very high quality psu, but it's not fully modular and I think it doesn't have hybrid mode?
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/66285-help-me-choose/
XFX is known for  great PSUs you should go with XFX. you should also check out seasonic and corsair rm series
I can not say anything of FSp because it is the first time I heard of that company
        # -_-     [Planned RIg AKA Project ARES    -_-#
| AMD FX-8350 4.0GHz 8-Core | Be Quiet DARK ROCK 2 57.9 CFM Fluid Dynamic Bearing | Asus Crosshair V Formula-Z  |G.Skill Ripjaws X 8GB Western Digital Caviar Black 1TB 3.5" 7200RPM |Samsung 840 Series 250GB 2.5" SSD | Sapphire Radeon HD 7970 3GB  |Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower|Gelid Solutions Silent 14 PWM 74.5 CFM 140mm x3 |Corsair RM Series 750 Watt ATX/EPS 80PLUS Gold-Certified Power Supply|
|Rosewill RNX-N250PCe | Windows 8  | Acer H236HLbid 23.0" |Corsair Vengeance K70
Corsair Vengeance M65 Wired Laser | STEELSERIES QCK Black|Sennheiser HD 558Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906154
XFX is what I use and they haven't let me down yet. (4+ yrs of constant use) I haven't heard of FSP before so can't really comment on them. What setup are you using this for? You probably don't need 1000w
i9 25.6 GHz with NeuronThreading, 256gb 6000 MHz RAM, GTX 990 OC 3024MHz 12gb, Skeletal X99 motherboard, 1 Petabyte SSD, Fractal Design Humaniod R1 Case, Herbivore 10,000W PSU, Noctua NF16 LP Derma Cooler.
Probably the only Star Citizen player who is planning on a career in Journalism instead of piracy, mining, trading, exploration, military, station management, etc.
Generation 0: The first time you see this add 1 to the number and copy it into your sig. Consider it a social experiment.
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906172
They are both great power supplies either one would work.
All XFX power supplies are seasonic and FSP isn't so widely known because they do mostly rebrands like fractal design power supples
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906173
So, do you need one overkill supply or the other?
Seriously, just get a 600W Seasonic.
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906229
Whichever looks better? Why do you want a 1000w psu? What are you planning on powering?
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906238
Just double checking but you do know you barely ever need 1000 watts.
oh, forgot to mention, I will use 2 GTX 770s or GTX 780s in the future, that's why I want 1000watts. Also I will overclock my cpu and want to have little free room too.
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906299
Why 1000w??
Also, might want to check out Corsair or Seasonic if you can. Other then that, I would say XFX
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906302
First, that is one aggressive looking PSU.
Second, I would go for XFX.
Third, is there some way you can send me your user pic??? I LOVE IT.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906341
Two 780's do not need 1000 watts, 750 watts on the low end, and 900 watts on the high end.
And in a best case scenario, a 900 watt PSU would only deliver about 850-875 watts. And then you have to factor in that as the PSU ages, it will produce less power (small amount as it may be, it can make a difference as I found out).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906348
Wouldn't that be sort of ironic since none of your PC's use Nvidia graphics cards.
My old rig used to have a GeForce4 MX 4000 AGP, and my Even Older rig used to have a RIVA TNT2 in it, but the RIVA overheated and the X1650 Pro blows away my old GeForce.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906390
here :)
http://i.imgur.com/kiRUyVI.gif
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906406
:D Words cannot express my happiness, so have this virtual cookie. O <<<That is a cookie.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
https://linustechtips.com/topic/66285-help-me-choose/#findComment-906453
