CPU PROBLEM? help me configure my PC please
Solved by kosamchetoo,
Yes, but if you can go 6th gen it's around 10% faster and should be almost the same price. If you want to use your current RAM then 6th gen is not an option as it requires DDR4 RAM.
Featured Topics
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting0 -
2
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
7
2
Shane Martin ·
Posted in Displays2
