i'd say from the back? lol
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541408
You access it from the other side (take off the other side panel)
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541410
You can't remove the cover, you need to access it from the back panel.
And you probably want to plug the cables into your PSU before inserting the PSU into the case, that's why the PSU was a bracket with thumb screws.
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541449
I did get access from the back panel, But its was realy hard to do anything with the psu, It was annoying to remove the PSU cables
Anyways when I'll have to plug them back do I need to get the psu out and connect the cabels to it from the outside?
Also, I tought I can do so because I've seen this picture of the case and thought it was possible -
http://images.anandtech.com/doci/9431/NZXTS340_12.JPG?_ga=1.58951277.132564378.1473753797
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541470
1) that's why you plug/unplug cables AFTER removing the PSU from the case
You can do it from the back if you want, it's just hard to see. I can do it without removing the PSU.
2) that is what the case looks like from the back...
You CAN do it from the back, but you said so yourself "it was really hard to do anything"
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541495
Ok thanks for that, Do i need to unplug the rest of the cables before removing the PSU or not?
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541505
What I do is unplug the cables from the motherboard, remove the PSU, then unplug the cables from the PSU.
Idk what you're doing with your PC so idk if you want to remove cables or not.
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541513
Thanks, I'll see what I'm going to do when I get the GTX 1070 hehe
Btw your case looking good!
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541525
Haha thanks :)
I see what you're trying to do, yeah I would disconnect the stuff from the motherboard and slide the PSU out, plug in the cables you need for the 1070 and slide the PSU back in and reconnect everything.
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541540
8 minutes ago, Enderman said:
Haha thanks :)
Hey also A question
Is there any significate diffrence beetween Gigabyte GTX1070 and the model with G1?
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541597
Hey also A question
G1 is just clocked higher, so i would go with the cheaper one and just overclock it yourself.
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541623
Which of the 1070 is the most successfull model of each aspect?
What do you mean?
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541706
1 minute ago, tROVLET said:
From cooling to performance
Which one is the best? (asus MSI gigabyte etc)
They all perform about the same, all the ones with 2-3 fans have great cooling, EVGA has great warranty, etc...
So get one that you can afford and looks good in your PC.
https://linustechtips.com/topic/660554-question-about-nzxt-s340/#findComment-8541726
