Need Info A8-7670k for GPU Addition.
Divu Kels
PC Specs:
OS: Windows 10 Anniversary Edition
CPU: A8-7670k (Overclocked to 4.2ghz)
Ram: Ripjaws Z Series 4x4gb 1866mhz
Motherboard: ASUS A88X-Gamer
PSU: Corsair 600w 80+ Bronze
CPU Cooler: Cooler Master Seidon 120v
Storage: 1 R3 120gb SSD, 1 Seagate 1tb HD, 1 Toshiba Laptop HD 500gb...
My question is will the A8-7670k bottleneck a GTX 1060 3gb or a RX 470 4gb.. there pretty equal in price and with out having to upgrade or change my cpu to a Athlon x4 860-880k series processor will my current CPU be to much of a bottleneck on one them two cards? I have considered the RX 480 as well but believe that one being more powerful would be a issue.. I understand my current cpu is an APU and all that its why im wondering before I get one of them two cards. Trying to find my cheapest route to upgrade Graphics from my intergrated graphics which I am using ASUS GPU Boost on Extreme Mode.
Just now, wrathoftheturkey said:
470 being more powerful is an issue? It'll still perform better. BOTTLENECKS ARE NOT ILLEGAL. There'll be a bottleneck with each card, but not much. Bottlenecks don't harm the cards, and the performance increase will be worth it.
 No what I ment was the 480 being more powerful then the 470 being an issue. Im just trying to make sure before I go out and spend a couple hundred dollars one of them will pare alright with this cpu other wise im looking at going cheaper on the gpu and grabbing an 880k if worse comes to worse.
Your APU is essentially the X4 860K with graphics. You're overclocked a decent amount already and disabling the iGPU may give you more overclocking there, too. The bottleneck will not really exist. I've been running my CPU as 2 cores 4 threads for over a month at 3.6GHz and no issues. While the 880K is Carrizo and has some improvements over the Kaveri/Godavari, in gaming your CPU cores will do fine.
You can see that here: http://www.gamersnexus.net/hwreviews/2394-amd-athlon-x4-880k-cpu-review-and-benchmark. Just compare the 880K to the 7870K.
CPU: i7 4770K  |  Corsair H80i  |  ASUS Z87-Pro  |  8GB Corsair 1866Mhz  |  GPU: MSI Gaming X RX 480 8GB  |  Corsair HX  750
Not really a huge bottleneck with those cards @ 60fps.
\\ QUIET AUDIO WORKSTATION //
5960X 3.7GHz @ 0.983V / ASUS X99-A USB3.1
32 GB G.Skill Ripjaws 4 & 2667MHz @ 1.2V
AMD R9 Fury X
256GB SM961 + 1TB Samsung 850 Evo
Cooler Master Silencio 652S (soon Calyos NSG S0 ^^)
Noctua NH-D15 / 3x NF-S12A
Seasonic PRIME Titanium 750W
Logitech G810 Orion Spectrum / Logitech G900
2x Samsung S24E650BW 16:10  / Adam A7X / Fractal Axe Fx 2 Mark I
Windows 7 Ultimate
4K GAMING/EMULATION RIG
Xeon X5670 4.2Ghz (200BCLK) @ ~1.38V / Asus P6X58D Premium
12GB Corsair Vengeance 1600Mhz
Gainward GTX 1080 Golden Sample
Intel 535 Series 240 GB + San Disk SSD Plus 512GB
Corsair Crystal 570X
Noctua NH-S12
Be Quiet Dark Rock 11 650W
Logitech K830
Xbox One Wireless Controller
Logitech Z623 Speakers/Subwoofer
Windows 10 Pro
Thank you everyone, you have helped my decision alot on this. Almost everyone else I talked to before coming here said it would be to much of a bottleneck... its why I decided to hit the Linustech forums. Im now trying to decide between a RX 480 or the GTX 1060... lol
