is it the way to go? i want to see your opinions..
im looking for a windowed m-atx case so you can actually see them sexy gpu's!
post links to themas well please
EDIT - needs to have a horizontal (flat) motherboard tray
EDIT again - accepting mini-itx form factors
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
https://linustechtips.com/topic/65771-m-atx/
Get the Corsair 350D windowed , awesome case and it isn't that expensive. as far as i know there aren't any good horizontal cases with a window.
I personally prefer mATX as ATX is really just wasted space. Very few ATX builds have enough graphics/sound/raid cards and things of the sort to actually justify needing the room for them.
For windowed cases something like a Arc Mini R2 or 350d are very nice options. You can always just add your own with a dremmel though :D
okay thx for input but
reason i said horizontal is so you can actually see the gpu, like it has amazing cooling system yet its facing downwards, you cant see it, just the ugly pcb :/
https://linustechtips.com/topic/65771-m-atx/#findComment-898469
mATX personally I see is the way to go. Compact yet has the ability to run SLI + RAID card with the right stuff.
true that! 350 dollar motherboard (nzd) so many slots.. uses one with a gpu and nothing else..
https://linustechtips.com/topic/65771-m-atx/#findComment-898477
m-atx is beast, Just wish they'd have a different layout
4x
16x
4x(or gap)
16/8x
That would be the beast layout so you could have two GPU's and a sound card/raid card without needing a raiser or Watercooling.
In fact I'm water-cooling my system just to run 2x GPU and my sound card at once (prefer internal)
I use a Haf XB case, it supports up to ATX, but mATX looks just fine in it.
Rig 1 CPU: 3570K Motherboard: V Gene GPU: Power Color r9 280x at 1.35GHZ  RAM: 16 GB 1600mhz PSU: Cougar CMX 700W Storage: 1x Plexor M5S 256GB 1x 1TB HDD 1x 3TB GREEN HDD Case: Coolermaster HAFXB Cooling: Intel Watercooler
"My day so far, I've fixed 4 computers and caught a dog. Australian Tech Industry is weird."
"It's bent so far to the right, It's a hook."
https://linustechtips.com/topic/65771-m-atx/#findComment-898653
4x
16x
4x(or gap)
16/8x
16, 4, 16, 16(8x)  :D
https://linustechtips.com/topic/65771-m-atx/#findComment-898685
nope, cause
4  x---- (sound card)
16x---------------- (GPU)
Gap
Might jump in ts and explain lol
https://linustechtips.com/topic/65771-m-atx/#findComment-898698
Get the 350D and turn it 90c. Then mod the bottom part and make a window. Problem solved!
I personally don't know any matx cases with a horizontal motherboard. I only know the Bitfenix Prodigy (not M) that has a window and horizontal motherboard. (but im sure there are alot more mITX cases with this option.
NZXT Phantom windowed, Asus Z77 Sabertooth, Intel 2600K, Noctua NH-D14, EVGA 780 Classified, Crucial Ballistic Tactical, Crucial M4 128GB + Samsung 850 EVO, Corsair RM850, Creative X-Fi Fatal1ty Peripherals: Sennheiser HD598, FinalMouse Classic, SteelSeries Qck Heavy, Ducky Shine Zero (MX Brown), AOC G2460PF & Qnix QX2710
Build Log: Phantom - Antique Noctua
https://linustechtips.com/topic/65771-m-atx/#findComment-898703
