Can I power a Xeon E3-1231V3 with a single 4 pin
I'm afraid many posters in this thread have spent far too long around the marketing hype and extreme high end. A single 4 pin ATX12V connector should handle up to around 190W (the connector itself - how much that PSU supplies is obviously going to be less). If you have a CPU which doesn't use much power a single 4 pin is perfectly acceptable. Look under the hood in tons of business PCs with i7s and lo and behold - a 230-300W PSU with a single 4-pin ATX12v. It's not sacrilege as these people are saying, it's pretty much the norm. Your super deluxe extra mega extreme ultra edition motherboards include multiple ATX12v connectors mostly "for the lulz" - connecting all them may help add stability in an extreme overclocking situation for an already high-wattage CPU. However, there's a good chance on a common i7 even on your 1337 board you could function just fine with a single 4 pin. It depends on your PSU obviously for how much it'll put out a single 4-pin but most CPUs are not consuming more than 150W. This means it's entirely feasible for a PSU to be designed to supply sufficient power over that single 4 pin
In most PCs the only real advantage you're getting from an 8 pin connector is slightly lower resistances - because you're nowhere close to overloading even a single 4 pin let alone 2 4-pins or 2 8-pins.
Sucks about the cable length - I've had the same issue with trying to re-use PSUs from OEM PCs. They combine unique motherboard layouts for where the power connectors are placed with custom PSUs with cables just long enough to reach their customized mobo. It's slick in the OEM PC, but an absolute no-go for anything else
