Whatever is best for a cpu is most likely also best used on a gpu, you do however have the option of using "paste" designed for use on "delidded" cpus as gpus do not have a heatspreader. Recommending a specific paste however is outside of my comfort zone. Hope this helped!
You need to find a paste that is non-conductive. Thickness and cure time shouldn't affect anything.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
MX-4 is great :)
NT-H1 is good too.
Choice of TIM doesn't really matter as long as it is a decent named brand it should be OK .  Be wary though of no-name cheap stuff, probably OK for a week or two but then it sets and has to be replaced.
Every other month it seems someone does a YT video on using household 'goo' as TIM the usual outcome is that most household 'goo' can be used as it is only a few degrees warmer in use than proper TIM, what these videos tend not to do is test the long term aspects of household 'goos'.
 Two motoes to live by   "Sometimes there are no shortcuts"
                                           "This too shall pass"
22 minutes ago, GeorgeKellow said:
I am putting a backplate on my MSI GTX 970 and I am going to clean the paste off and apply more. What is the best paste to use?
Based on CPU reviews Gelid Extreme is one of the best so it should be just as good for GPUs.
- Thermal Grizzly Kryonaut
- Gelid GC-Extreme
CPU: Intel Core i7 7820X Cooling: Corsair Hydro Series H110i GTX Mobo: MSI X299 Gaming Pro Carbon AC RAM: Corsair Vengeance LPX DDR4 (3000MHz/16GB 2x8) SSD: 2x Samsung 850 Evo (250/250GB) + Samsung 850 Pro (512GB) GPU: NVidia GeForce GTX 1080 Ti FE (W/ EVGA Hybrid Kit) Case: Corsair Graphite Series 760T (Black) PSU: SeaSonic Platinum Series (860W) Monitor: Acer Predator XB241YU (165Hz / G-Sync) Fan Controller: NZXT Sentry Mix 2 Case Fans: Intake - 2x Noctua NF-A14 iPPC-3000 PWM / Radiator - 2x Noctua NF-A14 iPPC-3000 PWM / Rear Exhaust - 1x Noctua NF-F12 iPPC-3000 PWM
- Gelid GC-Extreme
I haven't had any direct experience with Thermal Grizzly, but it's pretty expensive coming in at $12 for a single gram whereas Gelid GC-Extreme costs $13 for 3.5 grams.
Have there been any comparisons involving any Thermal Grizzly compounds?
Check out this thread. There's more on the web but I'm at work and don't have enough time to search.
Thermal Grizzly is the best but it comes at a cost, no doubt. It dethroned GC-Extreme  up top last year. The only ones ahead are the liquid metal compounds.
I just purchased an 11.1 gram tube of Kryonaut for $30 on Amazon. Yes it seems like a lot but having the best performance is worth the cost to me. That 11.1 gram tube will last you quite a while.
If that isn't an option for you then definitely get the GC-Extreme if you can. Arctic MX-4 is another good one.
@Trev450R  Seems a very big drop to attribute to just using a different thermal paste.
My Dell laptop is over 3 years old, and the thermal paste needed to be changed. Before I change the stock paste, the cpu playing a game was hitting 98'c with no extra cooling, and with my home made cooling fan 90'c. Now running the same game with the Grizzly Kryonaut 85'c with no extra cooling and 74'c with extra cooling.
