This is my first build. I am ready to buy, but I'm looking for feedback before. I plan on using this build for gaming and for schoolwork. I got the SSD for free and the case is on a deal. I am buying from Canada. Any help would be appreciated. Thank you.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($254.98 @ DirectCanada)
Motherboard: Gigabyte GA-H170-D3H ATX LGA1151 Motherboard  ($118.05 @ Vuugo)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($89.99 @ Amazon Canada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Newegg Canada)
Video Card: EVGA GeForce GTX 1060 6GB SC GAMING Video Card  ($353.28 @ shopRBC)
Case: Rosewill Stryker M ATX Mid Tower Case  ($64.99 @ Newegg Canada)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($120.11 @ DirectCanada)
Other: Unknown M.2 500GB SSD (Purchased)
Total: $1061.39
Generated by PCPartPicker 2016-09-06 19:53 EDT-0400
https://linustechtips.com/topic/655939-help-on-my-first-build/
Total: $1061.39
You can get a seagate 2tb barracuda for not much more
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471168
Total: $1061.39
Get 8GB of RAM, a 550W GS or G2 or even a cheaper 650GQ and you'll be able to afford a 120GB SSD.
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471184
7 minutes ago, iannaiian said:
This has more cost effective parts
the MSI VD boards have solid power delivery and USB 3.1, upgrade to the B150 board if you want 4 sata ports, I guess you need M.2 though?
the RX 470/480 are more cost effective than the 1060, and the 480 should end up faster with Vulkan/DX12 games
and how on earth did you get a 500gb M.2 drive for free?
PCPartPicker part list: http://ca.pcpartpicker.com/list/QdFwcc
Price breakdown by merchant: http://ca.pcpartpicker.com/list/QdFwcc/by_merchant/
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  ($69.99 @ Newegg Canada)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory  ($82.35 @ Vuugo)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.94 @ Vuugo)
Video Card: XFX Radeon RX 470 4GB Triple X Video Card  ($269.50 @ Vuugo)
Case: Deepcool TESSERACT WH ATX Mid Tower Case  ($34.99 @ Newegg Canada)
Power Supply: EVGA BQ 650W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($77.88 @ DirectCanada)
Total: $849.63
Generated by PCPartPicker 2016-09-06 20:08 EDT-0400
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471201
I disagree with the RAM amount (you want it to be on par with the rest of the computer), go 16gb. Everything else - yes. Slightly larger PSU and an SSD as a boot drive will take you a long way.
::[ PC GAMING MASTER RACE ]::
[ BUILDS ]
[ Junkyard Build ] (All parts were salvaged for free)
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471212
Total: $1061.39
I don't think you need to spend that much on a PSU... you should look at some alternatives
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471217
My dad is the president of a small engineering firm, he got it for an (any) employee but no one wanted it because they were having troubles with it in their laptops. My dad gave it to me because he wasn't using it.
Also thanks everyone for the help.
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471322
No games I've played have utilized over 7 GB and it's really, really easy to add another similar DIMM of RAM into your system later without issues. It would save him time now to get the 120GB SSD immediately and have a fast copy of Windows already running rather than going through a cloning or reinstalling mess later.
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471327
Sorry you didn't see, but I do have a 500GB M.2 SSD, so no need for a 120GB one.
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471366
He has a free 500gb M.2 SSD
This appears to be the same kind of MSI board, but with an M.2 slot, oh wait, I guess it's ITX, not that it matters too much, just go ITX lol
http://pcpartpicker.com/product/CsX2FT/msi-motherboard-h110ipro
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471383
Gotcha, well if it saves you money then feel free to grab an EVGA 650GQ :P
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471399
And then if you want the ITX build, the Elite 130 case is pretty cheap in CAD suprisingly, and it'll support long GPUs, everything should fit normally
https://ca.pcpartpicker.com/product/6wR48d/cooler-master-case-rc130kkn1
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471501
Would that case support the same motherboard (I'm assuming no). If not could you recommend any?
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471554
You are going to overpay for the GPU by almost $100!! The normal Newegg price is $260. Set up an auto-notify and snap it up once in stock.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471615
I think you misunderstood. The price is at $260 USD, but I'm buying in Canada for $360 CAD ($280 USD)
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471711
Oops. :o
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8471720
it'll support the ITX board with the M.2 slot I linked
that 1060 still seems overpriced given the 470 and 480 pricing a saw, but still, AMD is probably the way to go for the mid range
https://linustechtips.com/topic/655939-help-on-my-first-build/#findComment-8472101
