build advice $2000 build for gaming, Premier Pro, web design, and general multitasking. Curious to see what you would do with it.
Solved by The1whokill5,
RGB lighting? I would assume when people go with Windows your gonna add some light to it. Would probably spend the left over on some little stuff aswell. Like your build ??
but also would agree with the storage comments, but idk about giving up the 1080. Just because it's not supported well now dosnt mean it won't be in the future, and plus the card games better than the 980 as of right now, x12 is the only downside but I think the drivers will get better in the future and you'll be looking at a solid gpu
