HTML help
Julian5
So I bought a domain and a VPS last week and the server company has not contacted me with my login details yet........ so I already started programming and setting up the server at home. Its still a work in progress and it looks un- the proffesional since its been ages since I last coded in html5. Its really laggy rn (due to my bad internet) and its running on XAMPP apche. I cant get the favicon to work on the domain, it shows up in chrome when I search localhosr but not when I search my domain ( Juliantech.es ) notice the page is not fileld with info yet. Took me about 4 hours to set up the apached web server, domain and code the page. lemme know what you think
this is the code for the favicon
<link href="favicon.ico" rel="shortcut icon" />
and this is the code for the webpage index
<!DOCTYPE html>
<html>
<head>
<!-- Start WOWSlider.com HEAD section -->
<link rel="stylesheet" type="text/css" href="engine1/style.css" />
<script type="text/javascript" src="engine1/jquery.js"></script>
<!-- End WOWSlider.com HEAD section -->
</head>
<style>
ul {
    list-style-type: none;
    margin: 0;
    padding: 0;
    width: 200px;
    background-color: #f1f1f1;
li a {
    display: block;
    color: #000;
    padding: 8px 16px;
    text-decoration: none;
li a:hover {
    background-color: #555;
    color: white;
<body>
<style>
div.container {
    width: 100%;
    border: 1px solid gray;
header, footer {
    padding: 1em;
    color: white;
    background-color: #4d4d4d;
    clear: left;
    text-align: center;
nav {
    float: left;
    max-width: 190px;
    margin: 0;
    padding: 1em;
nav ul {
    padding: 0;
nav ul a {
article {
    margin-left: 170px;
    border-left: 1px solid gray;
    padding: 1em;
    overflow: hidden;
</style>
</head>
<body>
<div class="container">
<header>
  <font face="arial" color="blue" Size="8"> Julian's Tech Projects </font>
</header>
<nav>
  <ul>
  <li><a href="index.html">Home</a></li>
      <li><a href="workshop.html">Workshop</a></li>
    <li><a href="personal.html">Personal Projects</a></li>
    <li><a href="School.html">School Projects</a></li>
  </ul>
</nav>
<body background= http://projectspune.com/wp-content/uploads/2015/09/pcb-design-pune.jpg>
<br>
<center>
<font face="arial" color="white" Size="5"> My name is Julian, maker which attends Sotogrande international School in Spain, This webpage is meant to showcase my projects and explain how I made them along with some pictures.  </font>
</center>
</div>
<!-- Start WOWSlider.com BODY section -->
<div id="wowslider-container1">
<div class="ws_images"><ul>
		<li><img src="data1/images/dsc_0012.jpg" alt="Workshop" title="Workshop" id="wows1_0"/></li>
		<li><img src="data1/images/dsc_0014.jpg" alt="Workshop" title="Workshop" id="wows1_1"/></li>
		<li><img src="data1/images/dsc_0015.jpg" alt="Workshop" title="Workshop" id="wows1_2"/></li>
		<li><img src="data1/images/dsc_0028.jpg" alt="Air compressor" title="Air compressor" id="wows1_3"/></li>
		<li><img src="data1/images/dsc_0031.jpg" alt="Camera stand" title="Camera stand" id="wows1_4"/></li>
		<li><img src="data1/images/dsc_0032.jpg" alt="Air compressor" title="Air compressor" id="wows1_5"/></li>
		<li><img src="data1/images/dsc_0034.jpg" alt="cssslider" title="custom PC" id="wows1_6"/></a></li>
		<li><img src="data1/images/ff34409626444278a3905132c6370b6c.jpg" alt="Water cooled PC" title="Water cooled PC" id="wows1_7"/></li>
	</ul></div>
	<div class="ws_bullets"><div>
		<a href="#" title="Workshop"><span><img src="data1/tooltips/dsc_0012.jpg" alt="Workshop"/>1</span></a>
		<a href="#" title="Workshop"><span><img src="data1/tooltips/dsc_0014.jpg" alt="Workshop"/>2</span></a>
		<a href="#" title="Workshop"><span><img src="data1/tooltips/dsc_0015.jpg" alt="Workshop"/>3</span></a>
		<a href="#" title="Air compressor"><span><img src="data1/tooltips/dsc_0028.jpg" alt="Air compressor"/>4</span></a>
		<a href="#" title="Camera stand"><span><img src="data1/tooltips/dsc_0031.jpg" alt="Camera stand"/>5</span></a>
		<a href="#" title="Air compressor"><span><img src="data1/tooltips/dsc_0032.jpg" alt="Air compressor"/>6</span></a>
		<a href="#" title="custom PC"><span><img src="data1/tooltips/dsc_0034.jpg" alt="custom PC"/>7</span></a>
		<a href="#" title="Water cooled PC"><span><img src="data1/tooltips/ff34409626444278a3905132c6370b6c.jpg" alt="Water cooled PC"/>8</span></a>
	</div></div>
<div class="ws_shadow"></div>
</div>
<script type="text/javascript" src="engine1/wowslider.js"></script>
<script type="text/javascript" src="engine1/script.js"></script>
<!-- End WOWSlider.com BODY section -->
<footer> <font face="arial" color="blue" Size="2"> Julian Fernandez 2016 © </font> </footer>
</body>
</html>
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
It may be some caching issues and favicon may work after some time. Try to use other browser that you never used with that site, to see if it will work.
yeah I tried on all my devices, not working on domain only on local host
Elemental
Laptops
http://juliantech.es
I tried putting the link of the image but it still only works on local host.
Elemental
Laptops
Elemental
Laptops
Looks like there is no file you are referring to.
my file is named favicon.ico though, and how come it works on localhost then?
Elemental
Laptops
Another thing I noticed, the domain, it uses iframe to display your site, and the domain html document that uses that iframe has no favicon defined in head. Look yourself, check source of your homepage. It's more like domain issue, it should use redirect rather than iframe.
Ok im going to change it to httpd rn
Elemental
Laptops
Ok I changed it to HTTP, Does it work?
Elemental
Laptops
the problem is now I have it on HTTP, it shows my IP in the URL bar while  frame wont
Elemental
Laptops
IIRC you have to give the location of the favicon...for let's say its on drive D: and in a folder called favicon you have to do <link href="D:\favicon\favicon.ico instead of just saying favicon.ico
in this case it would look like this /mainsitefolder/assets/img/icons/favicon.ico or png take your pick. this is not the format of your directory but its how things should be sorted to keep things tidy.
So your line of code should be
<link rel="shortcut icon" href="//mainsitefolder/assets/img/icons/favicon.ico">
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
relative path works too, as it work on localhost, I would suggest remove all images for now so page load more quickly.
IIRC that's how your supposed to do it...
Yeah, but when you link things like this, browser starts to links them as file:///C:/xampp/htdocs/favicon.ico and it referees to YOUR computer, not remote one.
I made all the folders in the htdocs folder and this is the code inside the index.html
<link href="/assets/img/icons/favicon.ico" rel="shortcut icon" />
Elemental
Laptops
2 minutes ago, Mr_KoKa said:
Can you screenshot your directory where index is placed? Cause either http://83.63.237.164/assets/img/icons/favicon.ico and http://83.63.237.164/favicon.ico doesn't seem to be accessible.
should work now
Elemental
Laptops
also does your httpd config file have this line  "AddType image/x-icon .ico"
It is, http://83.63.237.164/
Now you need to chagne the way your domain redirects to your page, as I said before, iframe won't work, and to noth chagne address to ip you need to sett it up correctly.
ok how do i set it up so the IP wont show when I use HTTP redirect on the domain?
Elemental
Laptops
I have no experience with domain, but you don't want to use iframe, and unmasked redirections, there should be a thing that involve DNS to translate your domain to IP you provide. Just remember that DNS takes time to update, so it may don't work at all at first. There is your system DNS cache too, ipconfig /flushdns flushes that cache.
When you ping juliantech.es you it should return your ip address, not ip address of domain provider.
You can screenshot your domain panel where you set type of redirection, it may help to see what types are available to choose the right one.
Edit: I can see that favicon started to work with iframe redirection (I guess it inherits somehow), but anyway iframe makes your url to be static, so if oyu enter worksop link url remain unchanged, it makes unable to link to your workshop directly. It is just example why iframe is bad solution.
