He guys!
So lately I've noticed some bad lagging after I have booted up my pc (i7, GTX1070, 8GB RAM, Windows on SSD).
So whenever I turn on my pc and I've logged in, my mouse starts lagging for 10-15 secs which makes my pc unusable for 10-15 secs. Also typing in Chrome takes a while to make the letters appear.
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/653590-extreme-lag-after-boot-up/
Just now, AstroBenny said:
You probably have lots of startup processes. Go to task manager and disable any you don't need.
Only 5 enabled.
1 minute ago, AstroBenny said:
Can you open up task manager at boot and see what is using up all the resources?
Sure, will try it now.
Nothing is being used 100%.
14 minutes ago, JSD10 said:
maybe the keyboard and mouse lag is from the time it takes your keyboard/mouse drivers to start
Could be it, they are both controllable with the Logitech software.
8 minutes ago, wkdpaul said:
Are they wireless?
Nope, both wired
1 minute ago, xDanielxOossiex said:
Nope, both wired
could you post a screenshot of the "Performance" tab in task manager?
Should look something like this;
If you need help with your forum account, please use the Forum Support form !
Right after my pc booted up?
yes, right when it's actually lagging, else it's not really worth it, it really has to be when it's lagging (to catch whatever is responsible of the lag).
But, whenever you open Task manager > Performance and look at CPU usage, I always peaks to 100% for like 1 sec
that's not what I'm looking for, if the PC is already struggling, it's normal to see 100% spikes.
Take a screenshot when the PC lags, but not right the second you open the task manager. ;)
Here's a screenshot of when I just started up my pc.
3 minutes ago, Dawson Wehage said:
Could be Malware, Malware will normally increase your Random Access Memory and CPU usage to the max.
2 minutes ago, Dawson Wehage said:
Or your power supply might not be able to handle all that power, slowing down the computers performance.
Max power draw from wall (monitor included) is 345watts, so even with monitor included, my pc draws less than the 600W PSU.
Screenshot from when the pc is on for a little while.
ok, that's what I was suspecting, if you check Disk 2 you see it's at 34% usage right after boot, so it really seems it's something during your startup.
I've usually only seen lags like this when it's the OS drive being accessed heavily.
Go into the startup tab and disable everything to see if it still does it, let me know how it goes and we could investigate further after that!
Okay, thanks a lot!
Btw, highest temperature is 46 degrees celsius, and thats on cpu.
Edit: Double post, Idk why :P
Edited by xDanielxOossiex
Double post
