So I just finished up the water cooled experiment (pc was working fine) and Put the intel stock cooler on. I installed the gpu and no image (gpu was also working 10m ago). The fans spin but it wont display an image. I was thinking I might have overbent the mobo but its an intel stock cooler lol. No image from IGPU or DGPU.
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/652469-no-post-i-killed-it/
Double check all mobo power connections yet?
I am a paid professional, but only when I am at work...and getting paid.
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8379832
Yeah All pluged in; i reset cmos
Elemental
Laptops
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8379854
Elemental
Laptops
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8379877
I reseted them and no difference.
Elemental
Laptops
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8379893
Just now, swordsman247 said:
Tried it with the gpu out and in? The gpu had it's power connected as well?
Yeah I tried it wirh the gpu out and I checked all the connections to the gpu
Elemental
Laptops
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8379916
1 minute ago, swordsman247 said:
Well it may indeed be dead then, next thing would be to try the gpu in a different system or a different psu.
The gpu works in my other pc.
1 minute ago, RGProductions said:
try just rebuilding the entire thing. Works for me a lot. also try putting ram in different slot
All the ram slots are populated
Elemental
Laptops
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8379933
try just one stick, and every slot
If the ram was not working, it would beep anyways.
Elemental
Laptops
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8379944
11 minutes ago, RGProductions said:
try a diffrent power supply.
Ok I will try but Idont think its that since its nearly new and the fans spin all up
Elemental
Laptops
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8380018
no it wouldn't, seen it before.
just pull out all the RAM sticks and install only 1 and try other sticks and other slots if it doesn't work.
If you need help with your forum account, please use the Forum Support form !
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8381068
I re installed the cpu and It worked.
Elemental
Laptops
https://linustechtips.com/topic/652469-no-post-i-killed-it/#findComment-8385985
