Rethought build. Will this work?
Go to solution Solved by TheRandomness,
9 minutes ago, Aye_Its_Jay said:
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($368.82 @ B&H)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($88.33 @ OutletPC)
Motherboard: Gigabyte GA-X99P-SLI ATX LGA2011-3 Motherboard  ($187.98 @ Newegg)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2133 Memory  ($137.99 @ Newegg)
Storage: Samsung 950 PRO 256GB M.2-2280 Solid State Drive  ($186.99 @ SuperBiiz)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($76.88 @ OutletPC)
Video Card: EVGA GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card (2-Way SLI)  ($654.98 @ Newegg)
Case: Phanteks Enthoo Pro M Acrylic ATX Mid Tower Case  ($97.98 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($94.99 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.88 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($88.88 @ OutletPC)
Total: $2655.68
Generated by PCPartPicker 2016-08-31 12:57 EDT-0400
c:
See this to know my old build:
So, I no longer have a 1K budget. I have no budget anymore (dont be crazy).
I would like to know if this build would work for running high end games in 1080p ultra settings, while streaming.
Yes, that is a lot to do, but I really think my setup will work.
CPU: Intel I7-6700K (Amazon Link)
CPU FAN: Cryorig C7 (Amazon Link)
MOTHERBOARD: MSI Gaming Intel Z170A LGA 1151 (Amazon Link)
RAM: Corsair Vengeance 32GB DDR4 (Amazon Link)
SSD: Samsung 128GB (Amazon Link)
HDD: Seagate Barracuda 2TB 6GB/s (Amazon Link)
GPU: DUAL SLI EVGA GeForce 1080 (Amazon Link)
CASE: Phanteks Enthoo PRO M (Amazon Link)
CASE FAN: Corsair AF140 x2 (Amazon Link)
PSU: EVGA 80+ GOLD 1000W (Amazon Link)
OPTICAL DRIVE: Asus DVD-RW Drive (Amazon Link)
OS: Windows 10 Home OEM (Amazon Link)
WIRELESS: Asus Dual-Band wireless USB adapter (Amazon Link)
If you have any ideas for improvement, please let me know. I can give you the PcPartPicker link if you wish.
https://linustechtips.com/topic/652463-rethought-build-will-this-work/
great if you are doing 4k 1080p way over kill
I might do 4K. I want to keep it simple and never drop any frames while streaming, or rendering while playing.
yes at 4k great pc
Total: $2655.68
c:
USEFUL LINKS:
PSU Tier List F@H stats
Total: $2655.68
c:
I might do that CPU and SSD for better performance. Do you know if it is smart to replace my HDD with SSDs? It will be a few hundred more, but is it really worth it?
Not really as 1TB SSDs still cost so much. Also, the extra cores of the CPU will help with streaming and that SSD is NVMe, therefore it is much faster.
USEFUL LINKS:
USEFUL LINKS:
