might have to remove some of the drive cage, their site says 305 max without front fan and that's a 267mm card
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/651998-will-it-fit/#findComment-8375347
so then whats a better case i can get that has a window panel and looks as cool as the nzxt phantom? im also debating whether to get the strix 1080 or the ftw 1080.
https://linustechtips.com/topic/651998-will-it-fit/#findComment-8375380
Unless you have 7/8 hard drives then why do you need both cages? Your current case is completely and utterly fine yah know :P
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/651998-will-it-fit/#findComment-8375405
well it does make it so there's only 2 3.5 bays and maybe an ssd mount, just worth consideration imo.
I don't really like most computer cases, got a phanteks case and love it, gonna reuse it any time I rebuild my computer. That said Enthoo evolve itx would do, if you like the look, just doesn't have any 5" drive bays so you'd have to use an external drive, just shift around the case savings to that and you're good
desktop
HTPC
https://linustechtips.com/topic/651998-will-it-fit/#findComment-8375486
