6600k OC and Temps
12 minutes ago, Kevin_Walter said:Though my temps are hitting a maximum of 75c (69-73c average. 75 is max I've seen so far.) on the socket and core 0 according to CPUID.
This doesn't really seem safe to me.
So what are the safe temps for a 6600k? 70 seems like it would be the limit, though that could just be my brain saying so because I had an FX 6300 before and 70c was about the limit for that.
AMD measures temperature differently than Intel. They aren't comparable, and that's why we say up to 85C is fine on Intel, but a complete danger on AMD. Margins on FX CPUs are "lower" than Intel's.
Don't sweat about it, 70C is fine. For instance, mine's constantly touching the 80s 24/7.
15 minutes ago, Kevin_Walter said:This is on stock voltage, by the way. Obviously, if I push the voltage higher, it's only going to get hotter, so I'd like to push it as far as it can go on stock voltage and just leave it there. I've never been one for extreme OCs.
There's no such thing as "stock voltage". Auto voltage just means the mobo is putting it at whatever it wants to; might be 1.2, might be 1.4, who knows... regardless, you should never let the voltage on auto when OCing, even more so when using Prime95 (which, btw, I bet you are using either the wrong version, wrong test or both).
Put it at a fixed 1.3v and see if it's stable. That's what it took me to get 4263mhz out of my chip, you might be able to get 4.3 with it.
