My temps seem really high now, was lower before, but now that i check again, GPU is at 55 degrees C idle.
IDK what cpu is, because my AMD cpu is stupid and wont tell me temps acuratly,
System is a d5 pump with a dual 180mm rad, only 1 180mm fan on right now. But still, 55 is really high for idle.
Thoughts?
https://linustechtips.com/topic/649066-high-temps-custom-loop/
1 minute ago, PCNoobie said:
What is your gpu?
HD7950
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347351
Just now, PCNoobie said:
I'm not sure why you are getting that high, maybe the airflow of your case is bad, or ambient temp is just high.
radiator is outside my case, breathing the fresh airconditioned 70 degree (f) air
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347357
What other components are on yoyr loop?
Any idea at all what cpu it is?
General check list for custom loops though.
Is your pump functioning
is your block(s) mounted correctly
are fans spinning at proper rpm
is the loop clogged or auffering poor flow rate
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347362
Thoughts?
Could be build up in the block
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347369
Any idea at all what cpu it is.
FX-6300 and HD7950.
Pumps working, blocks should be fine, havent checked, but was fine before
fans are spinning as always
but actually, my computer bluescreened, and now the temps seem to be lowering.
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347374
Just now, spwath said:
FX-6300 and HD7950.
if overclocked, resset cmos and reboot. Infact, clear cmos either way and see if the problem comes back. Might habe been a mobo issue
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347386
I would suggest you to change the radiator position, because the warm air through your radiator is going to your psu.
No, here is a pic, pc is the box on the bottom, rad is the thing on top of the cabinet
plenty of open airflow
no OC.
But its working now after a bluescreen, so its all good.
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347399
Well keep in mind that you only have 180mm of surface area that's getting airflow. Sure, the other side is doing some cooling, but it's not nearly as effective as having two fans. Now if your temperatures have increased, I don't have a clue. Just remember that you have an old amd card and a cpu sharing that 180mm of surface for cooling.
ASU
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347448
Its been like that for a while. i need to fix my faulty electrical tape and speaker wire connection of the other fan.
Temps are down to 45c, which is normal for the single 180mm fan. Dual 180 gets me like 35c, and thats at minimum speed. So big.
180mm rad is the same amount as 2.25 120mm rads, so it should be fine
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347468
So, your pc is in close area? I think that's why gpu temp is really high, because the heat is kept in your pc.
No, the radiator is on top of the cabinet, in the free air.
Look at the picture, plenty of room.
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347471
not talking about the radiator, about your pc case
Thats fine, all the heat goes out of my pc case into the radiator.
Only a little mb heat is in the case, and i have ventilation for that.
And just a few weeks ago, my temps were in the 30's with same case.
But ive solved the issue, pc was just being weird and crashed and fixed temps
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347489
GPU I MEANT
Doesn't affect cooling what so ever btw. The air that comes out of the rad is barely warmer than ambient air.
https://linustechtips.com/topic/649066-high-temps-custom-loop/#findComment-8347959
