Is there a difference between USB cables?
Go to solution Solved by Glenwing,
Just now, Edgar R. Zakarian said:
Aside from the color white black and blue.
Or can you just add a white USB1 cable between an external USB3 HDD and your computers USB3 input?
What IS the difference in the cables physically?
USB 3.0 connectors have 5 additional pins in the back that aren't present on USB 2.0 or below. If a USB 2.0 cable is plugged into a 3.0 port, the port will only operate at 2.0 speeds.
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | KINGSTON SNVS1000G 1TB M.2 NVME SSD - Boot Drive | FSP Hydro PTM PRO 1000W |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
https://linustechtips.com/topic/648668-is-there-a-difference-between-usb-cables/
Speeds, amount of pins, compatibility with OS's, etc.Different devices are best suited by different types of connectors, the latest USB cable is the Type C
 | CPU: AMD FX 8350 + H100i | GPU: AMD R9 290X + NZXT Kraken | RAM: HyperX Beast 2033 16GB | PSU: EVGA G2 | MOBO: ASRock 970M |
| CASE: Corsair Carbide 88R |STORAGE: 1x WD Black | KEYBOARD: Corsair K70 | MOUSE: R.A.T 9 |
SOMETIMES LOSING THE BATTLE, MEANS YOU CAN WIN THE WAR
I've found that cheaper USB cables, like the kind you can get on ebay for a dollar, tend to not charge devices as fast as a higher quality USB cable.
I've even tested it with a 2A wall charger + energy meter. A cheap usb cable I got on Ebay charged my tablet at 2W. Quality cable that I paid $10 for at Walmart, charged the same tablet at 10W.
So yes, there can be a difference between usb cables depending on the quality of it. Though I'm guessing it's something like the size of the copper wiring inside of the cable that plays a role in this particular issue?
As for transfer speed though, didn't really test that "in-depth", but I didn't feel like it was slower or faster depending on the cable.
