Hi,
I am wanting to get a GTX1060 STRIX edition for my PC, but I am worried I will not be able to power it. Here are my specs:
AMD 7850K @ 3.7Ghz
MSI A88XM-E35
8GB DDR3 RAM @ 2133Mhz
Cooler Master Seidon 120V V2
1TB HDD @ 7200RPM
1 x Corsair 140mm SP fan
I have an NZXT hue+ lighting kit in my system too.
My PSU is a Corsair CS450M.
I plan on getting the non OC version of the STRIX.
Will I be able to properly power everything in my system?
Thanks,
Daniel
https://linustechtips.com/topic/647713-enough-power/
1 hour ago, Daniel Brad said:
Hi,
AMD 7850K @ 3.7Ghz
MSI A88XM-E35
1TB HDD @ 7200RPM
Thanks,
Daniel
You're fine and your PSU is of sufficient enough quality for a 1060.
Your CPU bottlenecks, on the other hand....
https://linustechtips.com/topic/647713-enough-power/#findComment-8333118
