Hello, I come from Greece and I am about to build a new Pc with these parts:
Motherboard: ASUS z170 pro gaming
Cpu: Intel Core i5-6600K Box
Gpu: Asus GeForce GTX970 4GB Strix OC
Ram: 2x HyperX Fury 8GB DDR4-2133MHz
What's your opinion on the Gpu?? Also, can you suggest me a good power supply not over 80 euros?? Finally any opinion, suggestion on these PC parts is welcome!
Thanks!!
https://linustechtips.com/topic/647612-building-a-pc/
1 minute ago, TrigrH said:
id go for a gpu with more than 3.5gb of VRAM
They already did.
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8331924
Why not get a 1060? The 970 is pretty old buy this point. For a decent power supply look around here:
https://linustechtips.com/main/topic/631048-psu-tier-list-updated/
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8331928
Just now, TrigrH said:
don't think so?
The 970 has 4GB of connected memory. 4GB is higher than 3.5GB.
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8331930
3 minutes ago, TrigrH said:
not to the crossbar
The memory controller is still enabled and connected. You can see it. It's just not connected to the crossbar directly because of the disabled cache.
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8331948
1 minute ago, Godlygamer23 said:
It's just not connected to the crossbar directly.
which is enough reason to not choose a 970 over the new offerings from AMD and Nvidia.
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8331958
Your point was that it's not there and not connected. It is there, and it is connected. It has 4GB of VRAM.
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8331961
1 minute ago, redmike said:
How about this one: MSI GeForce GTX1060 6GB??
thats a good option, also consider an AMD RX480 8gb or 470 4gb if you need to save some money.
it might as well not be, not sure why we need to be so technical, the 970 has 3.5gb of full bandwidth GDDR5.
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8331968
Thanks!!
why 6600k? are you going to oc? which fan for cooling cpu? why 16gb ram? storage? and yeah, 1060 is more recommended than 970
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8331985
Looks good, how much does it cost compared to the 970, RX 470 and the RX 480.
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8331987
it is about 60 euros more expensive compared to the 970!
And should be it's faster, how is the RX 470 and the RX 480?
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8332002
cooling cpu: CoolerMaster Hyper 212 EVO
storage: 1 ssd (240GB for Windows and games and programms) and 1 hdd(music, movies etc..)
why not 16gb ram??
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8332008
why not 16gb ram??
Most games don't make use it and you can upgrade it very easily down the line. Unless you want to get 32GB in the future can't find a reason why.
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8332019
22 minutes ago, redmike said:
so 12 gb should do the job??
8GB, upgrade later. Unless you want to get up to 32GB or make use the 16GBs of ram in something like editing or opening a crazy amount of tabs.
rx470 and rx480 are about 30 euros cheaper
In this case depends on you. The 970 will get you the best performance per euro, but on the other hand it won't last as long as Nvidia prioritises supporting newer cards in driver updates.
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8332080
ok thanks a lot!!
https://linustechtips.com/topic/647612-building-a-pc/#findComment-8332094
