so im turning a smal panini maker into a single sided heater.
the thing is, idk if im gonna burn my house down...
the schematic is this  :
ac---rez1---rez2
 î------I---------I
the heating elements were in parallel.
if I remove one, is there any danger ? (too much current for the single resistance remaining ?)
https://linustechtips.com/topic/647431-electricity-help/
If you remove one, the current through the circuit will decrease according to ohm's law.
The current through the overall circuit will be halved but the current through the two elements will remain the same provided the voltage across them doesn't change.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/647431-electricity-help/#findComment-8330004
same voltage. its plugged in ac.
I just remove the second element thats in parallel
https://linustechtips.com/topic/647431-electricity-help/#findComment-8330085
Leaving aside the very serious issues of regulatory compliance, and your house insurance being valid making such a modification not authorized by the manufacturer, removing parallel elements from such a circuit should not meaningfully change the heat dissipation in each individual element.
https://linustechtips.com/topic/647431-electricity-help/#findComment-8330090
but it does change the resistance and power draw. all the current is focused in one circuit instead of 2.
thats my problem and concern.
https://linustechtips.com/topic/647431-electricity-help/#findComment-8330147
Well, in an AC circuit, V = IZ.  V is constant (ie: what comes out of the wall).  Hence, I is inversely proportional to Z.  So if Z is doubled (ie: 1 identical parallel leg removed), then I is cut in half.
But seriously, if you don't understand a modification and the electrical rules behind it, you shouldn't attempt it.
https://linustechtips.com/topic/647431-electricity-help/#findComment-8330163
