Disk Space problem
2 hours ago, SSWolf1993 said:Well, how could I know what is included in right click/properties and what is not. I just googled page file and it has to do with some virtual memory. Why the **** is it as big as the windows folder itself...
It's where the stuff gets temporarily moved from RAM and back again. Consider it an extension of your system's memory. While it may not use it much if you have a lot of actual RAM (never expect zero usage, though), Windows will create a page file of a certain minimum size (either decided automatically or manually set) and adjust its size as needed (or not, if you set it fixed).
Windows may auto set it quite big, especially if you have a lot of RAm and hard disk space, but I don't really know the algorithm used to set the minimum size.
You can even completely disable it, although it won't give you much other than windows showing more free space in the disk
Many people will warn you against it, although if you have a lot of RAM you won't necessary experience any problem (I have two 16GB systems, one with and one without page file, and both run equally fine except when I run an own program which will require a manually set huge page file).
Most likely you'll be fine leaving it as it is.
