So i bought a gtx1070 because my gtx660 died, but what happend to it is that one of it's memory chip died so if i use it i would get tone of lines on the screen but i would get the same amount of fps in games. and so my question is, can i use it then as a physx card because it doesn't need to use the memory(frame buffer) because it won't be outputting frames or doesn't it work like that.
https://linustechtips.com/topic/647219-physx-card-help/
1 minute ago, rrubberr said:
There are plenty of games that don't really support the full gamut of Physx features if the Physx is done on a second card, and the 1070 is plenty for physx and rendering if you're running at 1080p. I wouldn't bother.
i wasn't asking if it is worth it i'm just asking if i can.
https://linustechtips.com/topic/647219-physx-card-help/#findComment-8327862
Data corruption will still be a problem regardless of use case.
CPU: Intel i7 - 5820k @ 4.5GHz, Cooler: Corsair H80i, Motherboard: MSI X99S Gaming 7, RAM: Corsair Vengeance LPX 32GB DDR4 2666MHz CL16,
GPU: ASUS GTX 980 Strix, Case: Corsair 900D, PSU: Corsair AX860i 860W, Keyboard: Logitech G19, Mouse: Corsair M95, Storage: Intel 730 Series 480GB SSD, WD 1.5TB Black
Display: BenQ XL2730Z 2560x1440 144Hz
https://linustechtips.com/topic/647219-physx-card-help/#findComment-8327864
2 minutes ago, | Rembo | said:
so what your saying is i would still get the blue lines even if i only use it for physx
I don't think you will get blue lines because its not an image being stored to the memory. Its simply positional data so a) things go extremely wonky in game physics wise or b) the game outright crashes because of the garbage positional values.
The RAM chips on the GPU do a lot more than just store an image. You should really just throw that card away and be done with it.
https://linustechtips.com/topic/647219-physx-card-help/#findComment-8327879
It might still work, but it will give you decreased performance then with just the 1070 by enabling physx because it is such a low end card compared to the 1070, and it will not be able to keep up.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/647219-physx-card-help/#findComment-8328031
