Problem with CPU
Solved by Thanatos246,
21 hours ago, Thanatos246 said:It's on my list to do, internet at home has just been too slow lately. Too many downloads on my consoles etc.
Will post as soon as this is done.
So finally managed to get Cinebench downloaded and after running it it seems my cpu is working as it should.
It looks like windows however is the culprit when it comes to reporting correct number of cores.
It seems to be reporting the number of modules as cores, so I have 8 cores, but 4 modules (combined/shared cores). So windows thinks the other cores are virtual cores and ends up not using them first unless under load.
I disabled virtualisation in the bios and that sorted out my issue of windows not using the cores.
Thanks for the suggestion's guys.
