i7 6700k not overclocking
Go to solution Solved by Killervolt,
You need to get a Z170 board to overclock . . . H170's don't allow it.
I am trying to overclocking my brand new i7 6700k to around 4.4ghz with just a ratio multiplier OC. However my bios will not let me set it higher than 4200mhz and even then, when I stress test, task manager shows it running at stock 4ghz. Intel Turbo Boost is enabled and I am using an Msi H170A Pc Mate motherboard. And CPU ratio mode is set to dynamic instead of fixed. Any help is appreciated.
Thanks.
https://linustechtips.com/topic/646910-i7-6700k-not-overclocking/
H170 boards don't allow overclocking. Plain and simple
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
also why are you using task manger
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
Just now, Xlockedbw said:
I feel really dumb. They even have a whole overclocking tab in the bios. I wish they would advertise that it is useless. Thanks guys, any other sub $100 motherboard recommendations for overclocking?
Make your budget up to $150 and get an ASUS Z170-a or similar model
