So I moved to a new apartment and won't be able to use any Ethernet cables but we do have 2.4GHz and 5GHz WiFi which has good signal. The speed is kinda shitty at 20Mbps down and 2Mbps up but I can deal with that.
I've only used wireless with my laptop and smartphone so I don't know of any good wireless network cards for desktops so let me know what you guys have had experiences with.
https://linustechtips.com/topic/644934-suggest-a-pci-e-wireless-card/
I have a
TP-LINK TL-WDN4800 N900
and would suggest it but in the last two months ive been having issues with it, Ive reinstalled windows twice, tried 10 and 7 with no avail. Having said that my ethernet is encountering issues so It might not be the wireless that is messing up.
Anyway I think im getting somewhere on fixing it, im using an old Hard drive which I used to use on this computer and it hasnt broken yet. Will try and update you if it doesnt break by the end of the week
5 hours ago, kris2340k said:
I have a
I can confirm this is a good card. I have this card personally in my gaming Rig for about a year now and it works great! I game on 5ghz and its like im connected to ethernet and works great for gaming!
[CPU: 4.3 GHZ I5-4670K] [MB: Gigabyte Z87-D3H] [RAM: Corsair Vengeance 1833 MHZ (8GB)]
[GPU: Gigabyte G1 Gaming GTX 1070] [PSU: Corsair CX-750] [Cooler: Hyper 212 Evo]
[Storage: 2TB 7200RPM HDD / 500GB Samsung 850 EVO ] [Case: ThermalTake Chaser-MK 1]
[Keyboard:Corsair K70 RGB Cherry MX] [Mouse: Razer DeathAdder] [Monitor: 2 x ASUS 24 INCH IPS (1440p Soon)]
Are you using Windows 10 currently?
It works in Windows 10 as my mom is using that card in a Windows 10 machine. Its just that, you use Microsoft drivers rather than TP Link. I have had some issues with this card in the past, reinstalling the drivers works. Other than that its a pretty good card, but its wireless N rather than AC.
Wireless N is fine as I only have 20Mbps down and 2Mbps up here.
Yeah, but if you ever wanted to transfer stuff across the network, AC comes in handy.
Yes Im using Windows 10, works fine.
