if i remember correctly, the blade stealth is a dual core cpu, and witcher 3 needs quad core to run.  You'll need to side-load a 3rd party software, i forgot the name, but it allows you to load the game, even with dual cores.
I had to do this playing on my dual core pc, when running the division, and farcry.  its dumb, as it works almost just as well, (actually, the division didn't work that well in the end) but ya.
google it a bit...   there is software out there that will help you load it.
It would be very hard to play even if you manage to launch the game. Even on low the game is a challenge on the 520 to run.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
13 minutes ago, KK said:
was wondering how to run witcher 3 on the razer blade stealth without the core.. i have seen people do it but i cant seem to be able to launch the game.....
Its going to run pretty badly even on low
kek no, the blade would also just overheat and performe even worse
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
1 - the CPU overheats so it's not possible
2 - the CPU is a power-saving ULV chip so performance is going to be bad regardless
3 - the iGPU is not capable of running the game even at 800x600
4 - the Razer BS is built like garbage and not worth the money
