Ducky Shine 3 (YOTS) vs WASD V2?
Solved by Zeal,
Ducky uses Cherry stabilizers while WASD uses Costar ones.
Each have their own individual feel. Many say that the cherry ones are a bit "mushy" as they never completely bottom out, but at the same time, Costar stabilizers sometimes ping when there's insufficient lube.
Both have their Pros and Cons, such as Cherry stabilizers being easier to swap longer keycaps (since you just pop it off) while with Costar stabs, you'll have to be careful not to bend the metal bar when removing shift/spacebar etc.
