Modem Struck by lightning, Now Pc won't work.
Solved by MrDrWho13,
2 minutes ago, LLamaGames said:That's what I was thinking I'm trying to find the model number so, i can look up specs and just buy her the same one. But I can't find it
It's probably a good time to get a new one. If you would like to build one, that would be the best option; but you can always buy a pre-built machine. You can take the hard drive out of her current computer and try it in another computer to see if her files are still there.
