My room has the doors open 24/7 and i have AC on at 21 degrees C  at all times (in the summer) but my room is still HOT AND THE AIR IS THICK AS FUCK from my PC and i also have 2 fans to help circulate air in the room.
My questions is, would replacing hardware help? (need upgrading anyway)
I current have a Hx1050 (Definitely overkill but i got a new one for free) should i replace with a smaller power one?
I'm currently using a GTX 680 which i already plan on replacing to a 1060 Soon.
What if i replace my H80i with an air cooler, would that even help?
What about my case? Im using an HAF 922. would getting something like an H440 even help?
BAHH! Any tips and tricks for my PC to release less heat?
I already turned off all my overclocking, and tweaked power settings to have more of a curve.
https://linustechtips.com/topic/642984-pc-heat-help/
Changing case or cooler will not help at all, because the same amount of heat will be output into the room.
The only thing that cooler and case help will be the temp of the components in the case.
To have lower heat you need to change your GPU or CPU.
A 1060 is much more efficient than a 680 so that will make a difference.
https://linustechtips.com/topic/642984-pc-heat-help/#findComment-8282654
The only way to reduce the heat released by the PC is underclocking and undervolting your current components to make them produce less heat. This will clearly result in lower performance. If you upgrade to newer components you will get better performance per watt and therefore lower heat for the performance.
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
https://linustechtips.com/topic/642984-pc-heat-help/#findComment-8282662
Should get a dehumidifier.
It helps to turn the furnace fans on during the summer to help circulate air through the house. It also helps to open the windows at night. One thing that's made a huge difference in my room was buying a window fan.
As far as heat management... Aside from underclocking, or using speed-step like features to dynamically control your clock and power usage, there isn't much you can do.
Even then, it doesn't solve the real issue which is a lack of adequate air circulation in your room. So basically, even if you do get lower powered hardware, or decrease the power consumption of your existing hardware, if you room retains it's current ability to disperse and get rid of this heat, then it's still going to continue to be an issue.
So, I recommend a peltier dehumidifier or a window fan.
One interesting idea may be to limit the exhaust of your PC to one output, and then create some ducting to run that hot air directly out of your window instead of releasing it in your room.
https://linustechtips.com/topic/642984-pc-heat-help/#findComment-8282670
Don't use it 24/7. If you must do something like encoding, do it at night when air in general is cooler. Shut it down when you don't need it, or use sleep if 30s boot is too slow for you.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/642984-pc-heat-help/#findComment-8283928
im guessing its an amd cpu xD?
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
https://linustechtips.com/topic/642984-pc-heat-help/#findComment-8286488
