A tad toasty, but I'd say that's a reasonable temperature. If you want to you can push down on the water block VERY CAREFULLY, if it cools slightly then you need to tighten whatever's holding it to the motherboard.
Edit: Wait, 647C? Yeah that's a reading error.
Edited by Citadelen
        Pixelbook Go i5 Pixel 4 XL
https://linustechtips.com/topic/639071-cpu-temps/#findComment-8242543
Your getting 100% CPU load at idle?
674C is a reading error, thats impossible.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/639071-cpu-temps/#findComment-8242561
