Its called a "PSU" for future refrence.
Ask for a build here. The first question should be "What is my primary usage for this machine" and "What is my budget"
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
https://linustechtips.com/topic/638684-ups/#findComment-8238611
I have the computer with psu Buld and look for a battery back up for it small price range just so it would not get interuped when the power go out so I cam save me my work
https://linustechtips.com/topic/638684-ups/#findComment-8238631
u noob.
OP: Just look around on Amazon and check the item descriptions to find one that is capable of delivering enough wattage, I'd expect to pay around $100
LTT's Fastest 9800gt
LTT Forum Beginners Guide
https://linustechtips.com/topic/638684-ups/#findComment-8238632
1 minute ago, catzambia said:
u noob.
xD I thought it was PSU that he was looking for
https://linustechtips.com/topic/638684-ups/#findComment-8238639
Just now, m2234323 said:
That look very good how to decide if I need one or not
I've got no idea what you just said but look at my post, i edited it and switched links.
https://www.amazon.com/APC-Battery-Back-BR700G-Uninterruptible/dp/B002RCNX8K/ref=sr_1_22?s=pc&ie=UTF8&qid=1470437854&sr=1-22&keywords=ups
use this one instead
https://linustechtips.com/topic/638684-ups/#findComment-8238659
it is hard to decide if I should get one or upgrade the gpu or cpu in the computer
https://linustechtips.com/topic/638684-ups/#findComment-8238664
Is that some kind of DJ console xD
https://linustechtips.com/topic/638684-ups/#findComment-8238672
Is your system going to be running mission critical tasks?
Do you have frequent brownouts in your area?
For most people UPS's are not needed. I do get 2-3 power cuts a year and 1-2 brownouts a month, and if my systems shut down unexpectedly I can lose up to 12 hours of work, which is why all of my systems are on backup power.
https://linustechtips.com/topic/638684-ups/#findComment-8238681
What are your specific components we can get a better idea of what you will require and as for needing a UPS itself if you experience a lot of power outages or brown out where the voltage fluctuate a lot then it would be a good option.
https://linustechtips.com/topic/638684-ups/#findComment-8240255
5 hours ago, m2234323 said:
here is the buld of the pc then a common monitor
http://pcpartpicker.com/list/DQzrVY
Your system wouldn't use more than ~375W so something like this would work even with peripherals and networking equipment.
http://www.apc.com/shop/us/en/products/APC-Power-Saving-Back-UPS-750/P-BE750G
https://linustechtips.com/topic/638684-ups/#findComment-8242628
