My Laptop Came with a 500 gb Hard drive with the Os and everything. I have been using my laptop fairly often , lets say 12 hours a day recently (probably more ) because i am on break from college ofc, However i wanted to back up my Os on a hard drive and i noticed some severe lack in transfer speeds . i didnt think much of it first but using HD tune 2.55 i saw that almost 70% of my drive is transferring at speeds around 1.5 mb/s. Should i be worried about my Drive Failing , cause linus said decrease in performance usually means that the drive is going to die, And if it is going to die, can i just copy over my OS files to another drive and swap it out or, do i need cloning software? , and if i do which is the most recommended
PC: Alienware 15 R3  Cpu: 7700hq  GPu : 1070 OC   Display: 1080p IPS Gsync panel 60hz  Storage: 970 evo 250 gb / 970 evo plus 500gb
Audio: Sennheiser HD 6xx  DAC: Schiit Modi 3E Amp: Schiit Magni Heresy
https://linustechtips.com/topic/638612-hard-drive-failure/
Use CrystalDiskInfo to check to see if the hard drive is going to potentially fail.
https://linustechtips.com/topic/638612-hard-drive-failure/#findComment-8237841
Definitely do this as you said this is your primary drive and has a lot of your information on it.
PC - NZXT H510 Elite, Ryzen 5600, 16GB DDR3200 2x8GB, EVGA 3070 FTW3 Ultra, Asus VG278HQ 165hz,
Mac - 1.4ghz i5, 4GB DDR3 1600mhz, Intel HD 5000.  x2
Endlessly wishing for a BBQ in space.
https://linustechtips.com/topic/638612-hard-drive-failure/#findComment-8237851
Thanks guys , but after another bench mark test , i saw significant improvement in performance
https://linustechtips.com/topic/638612-hard-drive-failure/#findComment-8238472
