you can share the drive from inside windows.
https://technet.microsoft.com/en-us/library/cc770880(v=ws.11).aspx
not all routers support drive sharing you will have to find that out.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
13 minutes ago, ChaoticFlare22 said:
Hello I have a 1tb external drive I just wanna find out how to put it on my network so I can access it from anywhere i just don't know how to setup an ftp server from within my router. Thank you for your time
Go to the hard drive itself. Right click it and then go on properties, once you've done that, click on the " advanced sharing" tab and select "share this folder" and select a share name for it.
Some routers support it. You just have to plug them into the USB ports on them if there are there and then set them up in the router settings
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
From ANYWHERE?
The cheapest options are:
A. learn how to use your existing router to enable the FTP server if it has it.
B. Install FTP software on your desktop (filezilla server) and configure your firewalls to allow external access.
C. Get a new router with FTP and/or Cloud features.
The least cheap options:
Buy a NAS device that you can put the drive into/plug into the back that advertises features for external WAN access. - but that will be double/triple the cost of your actual drive.
D3SL91 | Ethan | Gaming+Work System | NAS System | Photo: Nikon D750 + D5200
23 hours ago, ChaoticFlare22 said:
I think this is purely just a basic NAS - I don't see how you'd install Plex on it, unless you had a separate machine running Plex and were storing the data on this...
