Modding DT 990 pros?
Solved by Volbet,
While I don't want to take away the joy of a good modding job, have you considered just buying a pair of DT990 Premiums through the Beyerdynamic workshop?
That way you can have the wire and colour you want without the risk of breaking anything.
While I can't give you a step-by-step guide, I can confirm that it is a pretty simple job.
You just have to take take the left earcup apart by removing the screws, and then you just desolder the wire and solder in your own wire.
You could also just cut the wire and solder a male TRS on the wire, essentially copying the Superlux solution.
