sound card for HD558
Jirio
my on board sound is dying, looking for a cheap sound card, preferably one with a 1/4" headphone port because i don't like using the adapter.
internal/external doesn't matter to me, can't think of anything else but please ask if there's anything else you need to know. Thanks in advance :D
Use: music, mostly orchestral
current setup: 558's, on board sound (7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec))(idk enough about auido to know if thats exactly what you're asking for, thats the information from the mobo)
no other i/o, i only use the headphones
budget: would like something sub $80, it's really just a replacement for the on board sound
nothing real cheap is going to have 1/4"
I'd suggest finding a short cable adapter instead of the barrel adapter, that sennheiser includes, to reduce some of the stress on the jack.
fiio e10, e7, e17 or ibasso d-zero is about all I would recommend on the cheap side.
Will work for electronic components and parts
Reviews: Meelec CC51P - Monoprice 8323 - Koss Porta Pros  - Shure SRH-440 - Shure SRH-550DJShure SRH-840 - Hifiman He-500 - iBasso D4 - o2 Amplifier  -  SkeletonDac
sounds like i'm looking for a fiio E-10, thanks for the help guys :D
edit: I'll look into getting a cable adapter, i've had issues with that.
