My budget is about 900 US to spend on a computer that I want to build. Used pcpartpicker to confirm the compatibility between components and so far I found everything on Amazon for about 750 US (missing peripherals). But I wanted to know what you think about it? Is it good so far? Am I mistaken with the parts I'm picking out? (I attached an image with all the components so far or go to https://amzn.com/w/WXWB09XSEQ1 which is the list I also made on Amazon.com).
https://linustechtips.com/topic/631891-my-first-build-help/
I'd go with an Intel CPU, and an RX 480. Don't go AMD.
Also, are you planning on adding more storage later? If you plan on playing games you'll quickly run out with a 240GB drive.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/631891-my-first-build-help/#findComment-8158536
Yes I do plan to add probably a 3TB HDD to store games, the SSD I plan to install only the OS. What intel CPU do you recommend?
https://linustechtips.com/topic/631891-my-first-build-help/#findComment-8158542
Don't listen to everyone saying OOH BUY INTEl. Intel doesn't deliver the best performance for its money. Not only the Intel cpu is going to be much more expensive, but the motherboard will be too. In the end you will give 150-250 dollars more for the same if not less performance.
Edit: Replace the 970 with RX-480 or a 1060
https://linustechtips.com/topic/631891-my-first-build-help/#findComment-8158566
Depends if you want to overclock or not.
https://linustechtips.com/topic/631891-my-first-build-help/#findComment-8158570
10 minutes ago, SukaroBlue said:
i should of pointed out the gpu i'm just used to 970's being the standard gpu i guess. don't get a 970 get a 1060 or a rx 480 if you can find one. 970 aren't worth it anymore.
a used GTX 970 for about 180$ is a great deal to me
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/631891-my-first-build-help/#findComment-8158648
6 minutes ago, Mauricio Silva said:
But that would imply changing the motherboard, right? Because of the 6500 being LGA1151 not LGA1150.
It's the same motherboard you would need for the 6500k
https://linustechtips.com/topic/631891-my-first-build-help/#findComment-8158811
